Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › CDA CW494/1 tripping fuse
- This topic has 10 replies, 6 voices, and was last updated 18 years, 9 months ago by
gemcka.
June 21, 2007 at 7:52 am #28336
gemcka
ParticipantHi,
We have a CDA 494 dishwasher but it has started tripping the fuse on our fuse box.
it starts, drains the water, fills with new water – but as soon as the fill stops it trips the fuse and all downstairs electrics go off!
This happens on all programmes even the rinse.
Does this sound terminal?? it is definitely less than 5 yrs old but I can’t find any manuals we had with it or proof of purchase and I don’t know if we registered it with the manufacturer.
Gav
June 21, 2007 at 8:48 am #217939kwatt
KeymasterRe: CDA CW494/1 tripping fuse
Hi gemcka,
It’s a Whirlpool made dishwasher and I’m not terribly familiar with them.
However, there’s a few things that could cause this and I suspect from your post that you may be better to get an engineer in. You’re looking at testing a whole load of components for shorts or earth leakage.
At the age it’s worth having a look for sure I’d say.
August 15, 2007 at 10:09 pm #217940agwarn
ParticipantSounds like the wash pump to me, call CDA on 01949 862000 and for £69.99 they should come out and fix it
August 15, 2007 at 11:34 pm #217941Penguin45
Participantagwarn wrote:Sounds like the wash pump to me
Why?
August 15, 2007 at 11:49 pm #217942senseib
ParticipantRe: CDA CW494/1 tripping fuse
It will have one of those askell wash pumps fitted on this machine – so would be my guess too!
August 15, 2007 at 11:53 pm #217943Penguin45
We know that, Senseib – we even have an article al about it:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159I am merely concerned that a new poster is offering a definite fix, with no confirmed info to go on…….
August 15, 2007 at 11:57 pm #217944senseib
Point taken…
August 16, 2007 at 9:25 am #217945gemcka
Thanks to you all for your help & comments..
After getting the thing out of the cabinet – there has definatley been some leaking!!!
Looks like it came from the pump too.
Are they quite easy to replace?
I am a fairly competent diy’er, and if I get the Pump shown in the article – part 4812 361 58334 – is it a straight forward replacement, i.e same mounting points & electrical connections?Cheers.
Gav
August 16, 2007 at 6:18 pm #217946Penguin45
Clips can be tricky; there is a new bracket included to support the motor, but it is basically a screwdriver and pliers job.
With the power off, of course……….
Penguin45.August 17, 2007 at 6:47 pm #217947DentedPorsche
If CDA will come out and fix it for £69.95 then that’s gotta be a better deal than buying the parts and doing it yourself.
DP
August 20, 2007 at 6:31 pm #217948agwarn
After the dishwasher fills the motor should kick in, seems logical to question the wash pump but i accecpt it could be other things ie heater or leak (contacts for the motor are low and can get wet if the machine leaks) thats why i suggested calling CDA.
