CDA CW494 – Dishwasher not working! :(
Home Forums Public Support Forums Help And Support Dishwasher Help Forum CDA CW494 – Dishwasher not working! :(
  • #33238
    Fox-Bromham
    We bought a house in Halifax back in January, the dishwasher was already here but for some reason it’s now stopped working. The lights come on but the water doesn’t come out when we turn it on. Can anyone tell me why this might be? Whether it’s something we can fix ourselves or if we’ll need a professional? If that’s the case what are the costs of repair likely to be?
    Your advice would be greatly appreciated it.
    Thank you
    Liz & Mark
    liz @ eliza – fox . co . uk
    #237943
    Re: CDA CW494 – Dishwasher not working! 🙁
    Hi Liz,
    Is it not draining at all when you switch it on? If so there’s a number of things it could be, none of them are liable to be terminal.
    Are any of the lights lit or flashing as that would indicate a fault detected?
    Fox-Bromham
    Thanks for replying.
    The light above the button we use to start the wash flashes when we’ve shut the door and open it again to see why it isn’t working?
    Liz and Mark
    x
    #237945
    Count the pattern – ie 1-2-3-4-pause-repeat. That is an error code.
    Fox-Bromham
    Ok, NOW the light doesn’t flash but when you turn it on and shut the door it now bleeps once?
    x
    #237947
    It’s a Whirlpool made machine and what’s being indicated is that there is a fault by the flashing LED and beeping. the number of flashes tells us what general area the fault lies in, but not the exact nature of the fault, see this article for more detail on that.
    To erase the failure and try again press and hold the the start button for 1.5 seconds but, if the machine detects a failure again, it will flash up a fault code again. Without knowing how many flashes there are it’s not possible to help you any further really.
    TBH you may well be best to get some pro help and, on that machine, it’s likely to be worth it. You can find a local repairer using the repairs@ system on the site
    HTH
