CDA Dishwasher LV661
  • #15394
    bassman
    I went to this one Saturday not sure if mod number is correct no rating plate on machine got number off customers invoice from CDA, machine fills up starts to run ok when it gets to pump out it flashes fault code too much water, It continues to pump but just beeps and flashes fault.
    I checked pressure hoses and air bell evey thing is clear a very clean machine with no grease build up in any hoses.There is no sump float on this machine. If progran is stopped after fill and reset as soon as pump out starts the same fault occurs it’s as if the pump powering up brings the fault code up.
    I seem to be getting many faults now where the fault code either don’t exist or do not match fault that is occuring it’s driving me mad and taking hours ot sort out , is it just me or is anyone else experiencing the same problems
    #163419
    Dave_Conway
    Re: CDA Dishwasher LV661
    The model number is not correct but it’s almost certainly a Whirlpool, check the flow meter in the left hand side air break 😉
    #163420
    bassman
    Thanks for the info Dave but I don’t think this machine has a flow meter,
    The facia and controls are exactly the same as Baumatic but internaly it has a siamese pressure switch instead of a float arrangement also there is no drain pan or flood switch.
