CDA Dishwasher stops and flashes fault code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries CDA Dishwasher stops and flashes fault code
  • #80201
    MARIO
    Hi been to a CDA cw494 dishwasher. Which is Whirlpool in disguise. Service code 8545 494 15610 Ser No. 33 0120 018252. Select program washes then after 20 minutes it pumps water out and beeps with the rinse light on which is the first light of the 5 program lights and the select program light far end flashing .Tried to find fault code and think it is flood protection but no leak .Can anybody point me in the right direction thanks
    #412068
    Re: CDA Dishwasher stops and flashes fault code
    count flashes of the programme start button light. Can be up to about 15 flashes then a break then repeat
    MARIO
    That is the problem the light is flashing continuous no sequence, but the program you select changes to rinse light lit when it goes into the fault condition.
    #412070
    in any fault condition it goes back to first light ignor it its normal
    in this case you have fault 1 ntc failure
    one flash pause one flash pause etc so you cant see a sequence
    replace ntc if it goes ok if not its the board
    MARIO
    Thanks for your help Dave
