CDA door seal
  • #40608
    pmb
    Hi i went to a CDA CI993 washer dryer and have ordered a door seal for it, when i saw the machine i had a quick look to see how it fitted on but it wasn’t obvious. Are these a pain to do? or are there any helpful tips to changing these? I didn’t have time to look properly before because i wasn’t parked in a safe place any help would be really helpful
    thanks Peter 🙂
    #266994
    Lawrence
    Re: CDA door seal
    washing up liquid around the groove ,socket on long extension and you can just get to it through the top ,it is a pig to do last one I did was in the height of summer I lost a stone in sweat !!.
    Lawrence
    #266995
    pmb
    Re: CDA door seal
    Thanks Lawrence it sounds like i am going to have some fun today 😀
    #266996
    roly16
    Re: CDA door seal
    pmb wrote:Are these a pain to do? or are there any helpful tips to changing these?
    thanks Peter 🙂
    Remove the tub assembly.
    #266997
    Re: CDA door seal
    Sump hose is a tub out job…. It’s that hideous Fagor fingy which is a tub out job for the door seal. 😀
    Grendal
    Re: CDA door seal
    is that the same machine as the belling thats a tub out job for the door seal 🙁
    #266999
    pmb
    Re: CDA door seal
    Hi i got back with the right seal today and fitted it and it was a pain, it was nearly impossible to get to the bolt on the band so i cut the seal and tore it away. I did not want to even think about refitting the original band so i thought i would use one of the zanussi spring bands on the new one but it was to thick, luckily i had one of the beko ones which are not very good but thinner. Thanks everyone for getting back to me 😀
    #267000
    roly16
    Re: CDA door seal
    Was it fairly straightforward once you decided to use the Beko spring clamp? Can we have the Beko part no. for future reference please?
    #267001
    pmb
    Re: CDA door seal
    Yeah it was although i have to say the beko bands are very stiff and it took quite a while to get that on as it kept pulling the seal off the tub, if anyone else does a similar band you would be better off using that (maybe Bosch i can’t remember if this is a thick one). The only reason i had the beko band was that i took it off an old machine so i don’t have a part number sorry 🙂
