CDA DOUBLE OVEN MODEL CD 900/906
Home Forums Public Support Forums Help And Support Cooker And Oven Forum CDA DOUBLE OVEN MODEL CD 900/906
  • #15797
    ianjo
    Just had the aforementioned oven fitted. The temperature light adjacent to the temperature selector knob that controls the bottom oven doesn’t work anymore(it did initially) The oven works and that’s not an issue, what I would like to know is if it’s really worth messing around dismantling the thing etc to sort the problem or should I just let it ride…..so to speak.
    Views appreciated
    #166378
    Dave_Conway
    Re: CDA DOUBLE OVEN MODEL CD 900/906
    If it’s just been fitted (new ?) then the neon may have fallen out of it’s holder or a wire may be loose.
    Assuming it’s new then I would contact CDA and ask that they send an engineer to check it out, if a lead has come loose it could cause more damage 😉
