Hi Folks,
Motor goes to fast spin instantly and then cuts out after about one second and displays F08 (motor fault). Have tried spin cycle and a wash cycle at random and it did it both times.
90 ohms across tacho and ‘looks’ ok, ie it is not loose.
Removed and reattached motor terminal block and retested – no improvement.
I didn’t try removing and replacing the motor terminal to PCB, and nor did I look for a voltage at the tacho by spinning the drum. Instead, I – rather rashly – jumped to the conclusion that the module was at fault. Cannot see any damage.
Does anyone have similar experience of this? Is it a known fault on this machine? Thanks for any help
