CDA fan oven taking ages to heat up
Home Forums Public Support Forums Help And Support Cooker And Oven Forum CDA fan oven taking ages to heat up
  • #99972
    menderman
    Help needed please. CDA 9002/1 Oven. Noticed that oven started to be slow in heating up – about 1/2 hour to get to 200. The fan is working, took the fan and element cover off inside the oven and noticed that the element does not glow red.
    I did replace the same element almost 7 years ago for a slowly heating issue but that one clearly had a section that had expand and burst open but even in that state half of it still glowed red.
    #478706
    get plenty of blown elements with no damage at all
    you would need to measure the resistance with a meter to check if its failed
    menderman
    Thanks for your help. On closer inspection it does look like a slight bulge and distortion on a 3 inch section of the top of the 3 wound layers. It is screwed in from the back and by the time I have pulled it all out and got it out to test I may as well put a new one in I think. It is 7 years old which is about the age that I replaced the original one.
    Is there any on here.
    #478708
    its very likely this one but ask shop just in case
    You state model as CDA9002 but is it CD9002 ?
    https://shop.ukwhitegoods.co.uk/0620…n-oven-element
    This is a gen element which should be a better quality than the pattern units
    menderman
    Yes sorry it is CD9002/1
    I have also found this one https://shop.ukwhitegoods.co.uk/ele2015ego-premium-compatible-fan-oven-heating-element which says “premium” pattern at £16.96 and then there is an even cheaper one at £14. Not fancy the £14 but the £16.96 may be worth a go, not sure.
    #478710
    I would fit gen every time if the price is not silly
    had far too many cheap ones fail after 6 to 12 months
    menderman
    Thanks for your advice.
    #478712
    menderman
    Update. Sorry for the late reply, I replaced the element and its all working as it should now. After taking the old one off I could see only a slight deformation in it.
    One note for others is that the element came without a screw thread in the fixing plate holes so I had to search my box of bolt oddments to find 2 suitable m3 nut and bolts.
    I did fist contact CDA but they informed me hat they no longer supply that model element.
