CDA FWC150ss
  • #85002
    Arbo100
    I have a CDA FWC150ss wine cooler.
    It gets cold on the outside but is hot on the inside.
    I’ve taken all the covers off I can & gave it a good vacuum to clear all the dust but it still will not cool on the inside. It goes up to max temp, think this is 18c
    Think this maybe the thermostat??
    Thanks for any advice.
    Regards
    chezza
    Re: CDA FWC150ss
    Arbo100 wrote:Hi
    Regards
    Is the compressor running? If so, check if the cooling fan behind the compressor is running – it should run whenever the compressor runs. If the compressor isn’t running but the fan is, it may be the compressor that is failed…these are probably the 2 most likely things
    #427411
    Arbo100
    Re: CDA FWC150ss
    the compressor & fan are running.
    Found out it hasn’t got a thermostat but has a sensor inside the wine cooler so I’m thinking it might be this?
    cheers
    chezza
    Re: CDA FWC150ss
    If the fan and compressor are both running ( and not cutting out)then it sounds like a system fault- gas leak or restriction in the sealed system and will need specialist repairs. It wont be the sensor unless you are also getting error codes in the digital display
