CDA Oven CD601
  • #25718
    Lawrence
    This has got the wierdest fault I have ever seen video attached (hope it works)
    http://s55.photobucket.com/albums/g144/ … deo002.flv
    Basically when the oven thermostat is turned on the whole oven fades the clock dims and the fan slows to a halt .
    to date has had new fan element ,grill element ,toc,oven stat
    any thoughts
    Lawrence
    #207327
    tanner
    Re: CDA Oven CD601
    have you checked the connections at the spur other than that i would get an exorcist round there because i have never seen that before.
    stuart
    #207328
    roly16
    Re: CDA Oven CD601
    have you checked the mains terminal block for loose/burnt connections?
    measured the insulation resistance? Sounds like a high resistance connection or earth fault.
    #207329
    tanner
    Re: CDA Oven CD601
    it sounds like a loose connection at the wall arking or the like it is still the only obviose thing i can think of
    stuart
    #207330
    Lawrence
    Re: CDA Oven CD601
    240v supply at terminal block ,passes pat test okay ,supply seems okay at wall , wondered if an element was going down under load and acting as a resistor ,which is why I changed the two I have.Customer hopes that CDA will exchange ,I am not so sure.
    Lawrence
    #207331
    APG
    Re: CDA Oven CD601
    Laurence
    Have you a wiring diagram for this model?
    Is it a CD601SS or CD601/2SS?
    Andy G.
    #207332
    roly16
    Re: CDA Oven CD601
    Did you measure the voltage at the clock, or at the fan terminals when the thermostat was turned on, ie under load, to see if it dropped heavily?
    #207333
    Lawrence
    Re: CDA Oven CD601
    roly16 wrote:Did you measure the voltage at the clock, or at the fan terminals when the thermostat was turned on, ie under load, to see if it dropped heavily?
    Stupidly no ,I was running so late ,and the customer was of the mind to leave it and he would seek an exchange .
    If I go back I will try that thanks Geoff
    #207334
    BobHope
    Re: CDA Oven CD601
    this is a supply fault most likely on the mains connection box, the nuetral wire or link in the box has melted.
    Bob.
    #207335
    roly16
    Re: CDA Oven CD601
    I’d be inclined to have a word with the girls at CDA in the morning and tell them that the fault may be in the house wiring and you’re still investigating. That way they’ll be less inclined to exchange it and it’ll give you a bit more time.
    To establish whether it is or not, you could disconnect it from its present supply at the mains terminal box,, connect a test lead to it and temporarily plug it into another socket.
    I had a Haier -built CDA dishwasher that needed a pcb. The customer waited 4 months for that; they wouldn’t exchange it, so you’re probably in with a chance of finishing the job..
