CDA oven door hinge confusion
Home Forums Public Support Forums Spare Parts Help CDA oven door hinge confusion
  • #102243
    menderman
    Need a right hand side hinge oven is CD 9002/1 looking at the parts the one listed for the left is £14.95 but the one listed for the right is £26.95 then to add to the confusion the picture for the right does not seem to be the correct part as it has a screw tab on both sides when it should only have one on either the left or the right.
    Here’s the left https://shop.ukwhitegoods.co.uk/0631…ven-door-hinge which looks the correct part and here is the right https://shop.ukwhitegoods.co.uk/0631…ven-door-hinge here you can just see the “double screw tab which is wrong for the part. The casing also has a tapered cut off whereas the left is square.
    On my oven both left and right are the same apart from the single tab being either on the left or the right.
    I also cannot find the receiver for the hinge for the CD9002/1 oven
    Thank You[IMG2=JSON]{“data-align”:”none”,”data-size”:”full”,”src”:”https://www.ukwhitegoods.co.uk/forums/core/core/images/smilies/icon_smile.gif”}[/IMG2]
    #488056
    suggest you email the shop and ask
    menderman
    Thanks Dave – I thought the shop monitored these forums to be honest but will do.
    EDIT – Email sent
