Re: CDA oven fan motor.
Ordered the fan motor 5031685210809; it is completely different to the original. This new fan is the same as the Smeg ELE4208 give or take a mm. It will not fit as the mounting plate won’t sit flush against the support (lugs sticking up); there are no screw holes and the shaft is way too short even if you flattened the lugs.
The original is a three legged unit that is held in place by twist fit lugs pressed into the central steel support across the middle of the back of the oven cavity and secured by 3 threaded screws. I cannot find a single picture of the three legged fan motor on the net or anything useful about this model (apart from sales bumpf.)
Any help please or is it a case of ringing CDA direct?
Thanks!!
Steve.
