Cda pz10 small oven switch
Home Forums Public Support Forums General Enquiries And Questions Cda pz10 small oven switch
  • #96858
    Drkwcrusher
    Hi, has anyone come across this. The small oven switch is faulty and I bought a genuine replacement. The original has 5 spade connections, the new part has 7. It’s not a terminal for terminal replacement, but has the correct part number so has been altered by Cda. How do you connect it? I twice but the oven didn’t work in either configuration.
    #465079
    are the terminals numbered on the old one
    if yes may correspond to numbers on the new one
    where did you get the switch from ?
    Drkwcrusher
    Switch came from Uk white goods. Both switches have numbered terminals, but they don’t all fall on connections, so where there’s a 3b on one that’s connected, the 3b on the other is a space for example. There are more terminals available than wired connections on the new switch, but the spaces don’t correspond, hence it’s not one for one.
    #465081
    Have you emailed shop to check
    sometimes manufacturers fit different part before and after a serial number
    Drkwcrusher
    Yes I’ve double checked with them. The schematic of the cooker shows the original 5 connector switch with the same part number as supplied, but the new switch is 7 connector. Other sites have the same switch available, but none have details of how to connect. None that I’ve found anyway.
    #465083
    Drkwcrusher
    Yes that’s it.
    #465085
    this seems to be delonghi built so the often put part numbers on the switches
    so what part no is on the old one ?
    Drkwcrusher
    It’s the same Part number…
    #465087
    ok so we can assume it should fit we just need to figure out how
    from what I can see of 2 pictures of the different switches is they do have the same number of connection but some of them have 2 terminals to the same place
