CDA washer drier CI992 not unlocking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries CDA washer drier CI992 not unlocking
  • #64854
    DOCTORDOOM
    Hi, this gets to end of cycle and the door stays locked until powered off. Has anyone had this, i’m assuming it’s not the door lock because the locked light is still on.
    #358301
    Re: CDA washer drier CI992 not unlocking
    Yup .. door interlock
    Bryan
    #358302
    DOCTORDOOM
    Oh!! Shows what i know. I will get one then. Thanks
    #358303
    DOCTORDOOM
    Finally went back to this because I was not convinced it was the door lock. Fitted new one and it’s the same. I’ve got another customer with a CI993 with same fault. The door lock light is still on so I’m thinking it’s either got to be program unit or some kind of strange fault with the tumble drier. Anyway I’ve got two doing it now(and two new door locks to go in my spares I’ll probably never use box). Anyone had this.
    #358304
    blokes
    Not had that fault, but did have one with the washer heater gone made it do all sorts of strange things!!
    Steve
    #358305
    agwarn
    Are you sure the machines actually have a fault?
    Instruction book on page 4 states:
    To open the door, turn the machine off using the ON-OFF push-button and wait about 30 seconds after switching off the warning light before turning the handle to open the door.
    Hope this helps
    #358306
    allan73
    I’ve had this complaint from a new tennant for a letting agency.Looked in the instruction book and it did seem to read that the on/off button needed to be pressed, I reasoned that the previous tennant was using it that way and it did open after about a min.
    Allan.
    #358307
    DOCTORDOOM
    Thanks for the replies. Whats an instruction book???
    I do two buildings for a letting agent with at least a hundred of these machines and never had this complaint, also never seen a machine that needs to be turned off to release door lock but there you go…live and learn. Thanks again.
