No heat fault on this, heater is ok, Connect are showing the temp sensor for this as the usual twist fit one in the sump but the hole is covered. Does the temp sensor come with the optical sensor on this model as it looks more involved than the microswitch type. Can’t find a listing for this on Connect (no surprises) so not sure if my assumption is correct 😕
