CDA WC370IN cant select programme
Home Forums Public Support Forums Help And Support Dishwasher Help Forum CDA WC370IN cant select programme
Viewing 1 post (of 1 total)
  • #100249
    Karl Tyas
    HI all
    so I have moved house and it has a built in dishwasher a cda WC370IN
    the prep owner mentioned that it would only work in programme 7,
    however now i have moved in it will not select any programme at all
    just has 2 dashes when powered on, i have tried resetting pressing everything unplugging nothing works
    looks like the PCB is playing up, I’m competent enough to swap a pcb out my issue is this machine has 2 boards
    a main power board and a 2nd sister board with the programmes on etc
    my issue is knowing which board is at fault
    i have tested the button on the board that selects the programmes and it seems fine so its not the switch,
    anyone know which board its likely to be id take a guess at the sister programme board but want to be sure before buying
    the programme board is about 35 quid the other is about £80 so would rather not buy both if i don’t have to
    thanks all
