CDA WC430 – two flashes
Home Forums Trade Technical & Spare Parts Forums CDA WC430 – two flashes
Viewing 1 post (of 1 total)
  • #95311
    twicknix
    The fault has me stumped. Customer says it has 4 flashes, when I arrived and reset the machine. Ran it for 10 mins, opened the door for water temperature check then it did two lights flashing and beeps.
    Had and a look underneath and found water in base. Suctioned out and reset Dw, ran the quick wash prog so I can see if there are leaks. Nada. Opened the door, same thing happened two flashes and beeping noise, the base was lowered and the float is flat to the surface base. Dw won’t start after closing the door, reset and it works.
    Couldn’t put a finger on it as clearly that opening the door triggered the error code of two lights flashes.
    Any ideas?
