CDA/Whirlpool DW
  • #55101
    spimps
    Built in CDA DW 854549615861,looking for part no of motor/heater assembly,can’t find it on Connect or Masterpart,is it the sam as the BEKO one ?
    Any help appreciated.
    Customer paid £100 on flea bay and it doesn’t heat :rolls:
    will they never learn ?
    #321936
    chezza
    Re: CDA/Whirlpool DW
    motor is 4812 361 58478
    heater assy is 4812 259 28927
    very dear 😯
    #321937
    spimps
    Tested the heater from the front,presume the heater can then be removed from the motor part,is that correct?
    #321938
    chezza
    yes, it just twists together . If you are very lucky, it can sometimes be possible to remove and refit while in situ, without taking the motor off 😆
    #321939
    spimps
    Now that is pricey 😯 good job I collected the call charge as that will be the end of that one.
    Cheers for that.
    BG
