Cda/ white knight dryer
  • #94047
    kaibart
    Hi guy got this cad/ white knight dryer model number Ci921 030483115021 with no heat checked heater fine checked all stats fine so I suspected pcb fitted pcb work when I was ther now it has recalled any ideas where I should be looking Tia kai
    #456269
    suedehead1
    Re: Cda/ white knight dryer
    did you check the exhaust thermostat on the duct near the motor
    #456270
    kaibart
    Yes all checked I’m baffled
    #456271
    kaibart
    I’ve changed the pcb heater resettable stat and exhaust stat and I have no power to the heater anybody any ideas
    #456272
    well looking at the wiring diagram it could not be simpler so cant think why its not working
    few thoughts
    its a sensor dryer so may not heat without lots of damp clothes in it
    on the same note if the drum sensors are not connected to the board or compromised in some way so as to make the board think the clothes are dry
    kaibart
    I’ve got resistance between the paddle and brush aswell what’s got me it’s something I’m overlooked somewhere but I can’t think what
    #456274
    its so simple there is almost nothing to overlook
    have you double checked there is only 1 board for these machines
    and there is no way you could have connected it wrong accidently
