Cda563fw-2 beko Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Cda563fw-2 beko This topic has 12 replies, 3 voices, and was last updated 13 years ago by mikeday1. Viewing 13 posts - 1 through 13 (of 13 total) Author Posts April 1, 2013 at 9:06 pm #74836 mikeday1Participant Hi chaps. Beko fridge freezer. How do they sense the temperature in the fridge?. There is no thermostat just a small Pcb which the temp adjusted is pushed into. No sign of a thermistor. Only in the freezer. April 1, 2013 at 9:13 pm #393037 mikeday1Participant Are there any beko refrigeration engineers on here. Hi. How does the beko Cda563fw-2 sense the fridge temp. There is no thermistor in the fridge section only a small Pcb to which the temp adjuster is fitted. Pls do not tell me it’s sealed into the cavity. Mike April 1, 2013 at 9:48 pm #393038 iadomModerator Re: Cda563fw-2 beko Merged your two posts Mike, somehow don’t think either of them belonged in The Rumour Mill. 😉 April 1, 2013 at 10:17 pm #393039 mikeday1Participant Re: Cda563fw-2 beko Ok. Thought people might see it quicker April 1, 2013 at 10:25 pm #393040 iadomModerator Re: Cda563fw-2 beko Not really, it is Bank Holiday after all. The best thing to do when any post has not had an answer after a while is to ‘bump it’ yourself. 😉 Jim. April 1, 2013 at 10:27 pm #393041 mikeday1Participant Re: Cda563fw-2 beko Ok no problem. Have a answer in a private message so all good 🙂 September 15, 2013 at 4:47 pm #393042 jongriffinParticipant Re: Cda563fw-2 beko did anyone ever let you know if there is a sensor that can be changed in fridge section…seeing a few with this problem. September 15, 2013 at 4:52 pm #393043 mikeday1Participant Re: Cda563fw-2 beko The sensor is on the Evap inside the freezer section September 16, 2013 at 7:52 am #393044 jongriffinParticipant Re: Cda563fw-2 beko so the sensor on freezer evap controls fridge temp…is that right? September 16, 2013 at 8:03 am #393045 mikeday1Participant Re: Cda563fw-2 beko That’s what the tech info says September 16, 2013 at 8:09 am #393046 jongriffinParticipant Re: Cda563fw-2 beko tbh cant see a sensor in freezer section either on diagram..have you part number please? September 16, 2013 at 8:16 am #393047 mikeday1Participant Re: Cda563fw-2 beko Evap sensor 4394720185 Air sensor 4394720285 September 16, 2013 at 9:33 am #393048 jongriffinParticipant Re: Cda563fw-2 beko Thanks for your help Author Posts Viewing 13 posts - 1 through 13 (of 13 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
