Cda648fw/1 beko fridge freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Cda648fw/1 beko fridge freezer
  • #78260
    mikeday1
    Hi guys.
    Having a problem with this fridge. Customer complaining that the fridge is freezing on min setting.
    This is the one with the thermistors rather than thermostat.
    Anyone have any ideas.
    Regards
    Mike
    #405014
    Seamy
    Re: Cda648fw/1 beko fridge freezer
    Maybe its getting low on gas & running continuously, is it actually below zero degrees in fridge or just a lot of frost on back wall?
    #405015
    mikeday1
    Below 0 in fridge
    #405016
    Madmac
    Have the same prob with a Beko CDA563FS, running continuously & freezing the fridge contents.
    Full electronic control on it, anyone know of a common failing on these causing this fault? It’s only around 3 yrs old.
    Thanks.
    #405017
    A1applianceservice
    Having the same problem with a Beko CDA648FW/1. Fridge contents being frozen. Engineer has replaced POT Board 4360635285, Module 4360620185 but fault persists. Engineer now wants to change the fridge sensor… lets see if this solves the problem! Does anyone have access to an exploded diagram?
    #405018
    Lawrence
    If it’s not an American style then the sensor is foamed in
    #405019
    SAMURI
    Fridge evap sensor or low on Gas is the only 2 possible problems.
    If the fridge evaporator is freezing evenly over the wet wall then the sensor is the problem.
    If the fridge evaporator is only freezing near the top then it’s low on Gas.
    Bob
