Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › CDE129ALL Module /Wiring Mod/Smartcard
- This topic has 3 replies, 2 voices, and was last updated 10 years, 1 month ago by
aroffauz.
March 1, 2016 at 12:27 pm #87761
aroffauz
ParticipantHi
I have a CDE129ALL Ariston integrated washer dryer S/N 410113629 – 8032700000
could anyone advise the correct part numbers for the replacement Control Module if there are wiring modifications with the replacement module and the correct Smart card ( there are three listed on partfinder)
Many thanks 😀
(picture attached)March 1, 2016 at 2:51 pm #435903iadom
ModeratorRe: CDE129ALL Module /Wiring Mod/Smartcard
Do you mean the control module or the main power module in the base? No smart card needed for the control/facia module.
All the information regarding any wiring changes, module part numbers and eeproms is on Partfinder, although the commercial code you have given may be incorrect, it should be 032570.
It looks like a bit of a minefield due to module production changes on these, even a possibility that you may need the earlier type of module with a removable eeprom, heaven knows.??????
March 1, 2016 at 7:01 pm #435904aroffauz
ParticipantRe: CDE129ALL Module /Wiring Mod/Smartcard
Hi Jim
It is the main Power Module in the base – apologies the commercial code is 80325700000.
The original module does not have a removable eeprom
I believe the new module C000254298 is correct
wiring mods C00142746 ( to valves and NTC) and C00142747( to fan motor) may be required.
Although there are three different smartcards listed ( the ” view notice” in partfinder says ” for correct programme card /file check description against the part code in partfinder CD or Servicenet parts list.” ( I have the partfinder CD but do not understand where to check and I do not have access to Servicenet parts list)
C00262025
C00262115
C00262966
This machine may have originally been supplied in Italy as it was part of a “POD” kitchen which was supplied with appliances already fitted . I don’t know if this has any bearing
Thanks DeclanMarch 1, 2016 at 7:05 pm #435905iadom
Sadly I do not have access to Servicenet either. 🙁
And the information in Partfinder is worse than useless.
