Ceramic hob cut out size
  • #90021
    folleyball
    Hi sorry if this is in the wrong section.
    I’m trying to find an electric ceramic hob that will fit a granite worktop with a width of 55cm. Most of them are 56. Whirlpool did one (AKM359NE), but it’s not available anywhere.
    The current one is a really old Diplomat.
    Many thanks
    #443287
    AMS
    Re: Ceramic hob cut out size
    Have a look at the hobs on ao.com. In the technical specs there is often the cut-out size required, often in the FAQ’s.
    #443288
    Or use a hand grinder with a cutting disc to grind off the extra couple of mm you require. use plenty of water else it’ll get very dusty.Ive done this without a problem as you would not be leaning on top but from within the present hole.
    Bryan
    #443289
    trotter
    http://www.montpellier-appliances.com/p … amic-hobs/
    This one should fit without the clips 😉
