My house was built in the early 80s so the wiring is reasonably modern. The oven is on its own circuit protected by an RCD in a new consumer unit.
My question is, if I fit a ceramic hob, is it likely that I will need to provide a separate supply tail from the consumer unit or can I just connect it to the same supply as the oven?
