I have a creda double oven with ceramic hob top (C362). It has been badly scratched on the front right ring obviously by a metal pan scourer and the dark colour has been scratched off. I presume it is still usable? (this is a holiday cottage). Can you get the hob glass part replaced?
Thanks. Not sure worth replacing then – just looks bad and is annoying as it has not had a full season yet and I make sure I only supply non-stick sponges. As long as with it sratched down to white it will still work ok and is safe.
