Change bearing on Hoover HSW 150M
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Change bearing on Hoover HSW 150M
  • #46517
    DerekARF
    Can the drum bearing be removed without taking out the complete drum. i.e removing the nut, pulley and drawing out the bearing.
    #289849
    Simon46
    Re: Change bearing on Hoover HSW 150M
    No front bearing has to come out.
    S.
    #289850
    DerekARF
    Thanks – an engineer says it is better to scrap the machine, too expensive to repair. Machine is only 5 years old and had a new motor. Is this right?
    #289851
    It’s all about time…… To an experienced professional repairer this a two – two and a half hour job and time is money. A bearing and seal set alone is not particularly expensive – £15-£25 typically, so it’s cost effective to you to do it for yourself.
    The stumbling block with all bearing jobs is that until the machine is apart you can often not judge the condition of the drum shaft – on a Hoover/Candy appliance, this is usually the inner drum and shaft as an assembly = expensive.
    HTH,
