Changed the belt now the dryer won’t work
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Changed the belt now the dryer won’t work
  • #28191
    flybouy
    AEG lavatherm 57700 condenser dryer started making a loud vibrating noise and I found out the drum wasn’t rotating. Upon opening saw the belt was quite loose and bits were shredded. Got a new belt and installed it but the noise is still there and the belt is loose. I have looked at the posts on this forum and made sure I route it in different ways but there doesn’t seem to be any way to tighten the belt. Ihave checked and it is the right size. Any help will be appreciated.
    #217307
    Re: Changed the belt now the dryer won’t work
    PNC number please – lots of different 57700s.
    flybouy
    Went to sleep on it and the solution struck me at 2am in the morning. I saw which way the spring was pulling and I figured that the belt has to pull inthe opposite direction to give the belt tension.
    There seems to be a bit of a squeak that has developed as the drum rotates. Any ideas? Have I got the beading and gasket at the back the wrong way round perhaps?
    Cheers
