Changing a thermostat(app6403)
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Changing a thermostat(app6403)
  • #28948
    marley102
    Hi anybody,
    could anyone tell me if they changed a thermostat on a schreiber app6403, how easy is it? the model i have the thermostat is located behind the front control panel.I have just installed a new motor in our dyson hoover,would this be the same difficulty level 😕
    #220798
    clivejameson
    Re: Changing a thermostat(app6403)
    marley102 wrote:I have just installed a new motor in our dyson hoover,would this be the same difficulty level 😕
    Definitely not….at least you won’t have to remember where so many bits fit back together 😆
    #220799
    marley102
    thanks for the reply clive,
    at least you know where to start on a dyson.I’ve had a look at the front control panel.obviously doesn’t screw off.does it just pull away from the freezer itself.maybe i should leave it to the experts.trouble is the expert i got couln’t even dignose the problem.
    thanks again
    marley102
    #220800
    clivejameson
    marley102 wrote:trouble is the expert i got couln’t even dignose the problem.
    marley102
    Perhaps the ‘expert’ wasn’t so after all?
    Might be worth clicking the link below to find a local engineer to correctly diagnose the fault before you start spending cash on parts 😉
    #220801
    fridgeman999
    You need to pull the machine out, on the top is a plastic cover, remove the cover and you see the pcb, not a thermostat, push knob out, and then slide pcb up.
    #220802
    With the power OFF at all times………….
    Penguin45,
    Moderator.
    #220803
    fridgeman999
    Ooop’. Sorry, yes forgot that one! 😀
    #220804
    marley102
    thanks for all the help I’ve received.My freezer is now working:lol:.The hardest part of that job is pulling the freezer out in the first place.Anyone thinking shall I,Just do it.
    thanks again for everyone’s help
    Marley102
