Changing direction of door opening of Ocean FFC 42-29
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Changing direction of door opening of Ocean FFC 42-29
  • #10497
    daricoid
    Just moved in to rented accommodation and the landlord has placed her Ocean FFC 42-29 fridge/freezer in a very awkward place and therefore access is restricted due to the doors opening out to the right. I was hoping somebody knows how to change the door so that it opens the other way. Is it a case of removing the top and bottom panels and gaining access to the hinges underneath? Can you just pull off these panels? When I tried it sounded like I was snapping the plastic.
    Any help and advice would be appreciated.
    Thanks,
    Daricoid
    #140322
    Dave_Conway
    Re: Changing direction of door opening of Ocean FFC 42-29
    That information should be in the user manual, as it’s likely you won’t have it, you should be able to get one from Brandt UK on 012 56 30 80 00
    Hope that helps.
