Changing Door Swing on Zanussi ZDC67550W Dryer?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Changing Door Swing on Zanussi ZDC67550W Dryer?
  • #35654
    werdas
    my model is zdc67550w,
    it says it is reversible, + it looks like, just when I started to do the job I notices if I would unscrew completely door catch it would stay/fall in under front panel.
    Everything was straightforward and easy and until you get to the door catch lock which is located inside the machine. Does anyone know what is the easiest way to access this so I can move it to the other side? Does it involve taking off the main cover or what?
    SO I had to stop, and seek for a advise
    #247486
    JJW
    Hi, did you have any luck changing the swing of door? I am looking at getting the same dryer but didn’t want to pay for engineer to change door. Thanks
    #247487
    silverbroom
    Re: Changing Door Swing on Zanussi ZDC67550W Dryer?
    Hello, this is not a job that you should consider as a DIY project.
    In the Zanussi engineers manual is a 30 stage procedure ending with a safety test using a dynamometer in relation to the door being able to be opened from the inside should a child crawl inside.
    Sorry but your best and safest option is to call an engineer.
    silverbroom
