chinese zanussi zwf1221w
  • #80811
    dpr1974
    evening all, i can’t work this one out. what ever program you select, it won’t do anything and then the end light comes on. error code is 34 (temperature sensor fail) however the thermistor and heater tested ok but i fitted one from stock anyway. does the same fault!?
    door lock is good as is the pump and motor (including brushes)
    any ideas?
    unless i can’t see the wood for the trees then i presume it’s a board fault, if so is there any common faults with these or anyone know what component is at fault, and just for the fun of it i’ll type “fault” again 🙂
    cheers
    David.
    #414401
    Re: chinese zanussi zwf1221w
    Firstly it is not a Chinese machine but made in two factories in Spain. There are two basic versions and twelve variant production runs (always pays to give us the PNC number by the way).
    Finally, E34 is a pressure switch based error.
    #414402
    dpr1974
    Sorry about that Martin, i assumed this was chinese as the only e34 i could find in the UKWG fault guide was under chinese zanussi.
    would be the only thing i didn’t check 🙁
    many thanks
    #414403
    If you email me with the full PNC number I can send you some info on it. 😀
    #414404
    dpr1974
    Thanks Martin for the offer but i tested the pressure switch and found the problem.
    #414405
    Result then. :tup:
