Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Choosing a new dryer
- This topic has 10 replies, 6 voices, and was last updated 16 years, 4 months ago by
Chris_B.
November 12, 2009 at 12:01 am #50087
Chris_B
ParticipantOur Hotpoint TDL30 has been used daily for over 7 years, but has needed a lot of looking after – I think it’s on its 3rd or 4th rear bearing, 3rd front bearing, 2nd rear seal, etc. It’s now very noisy, for no reason I can diagnose. (I’m a Chartered Engineer, and do my own servicing of just about everything except gas appliances). I’m planning to replace it and looking for advice.
I like the ISE machines, except that they are Energy rated C. Compared to a Siemens WT46W560GB which is A rated, it could cost £50 or £60 a year extra to run an ISE. I’m surprised, given the ethos of ISE, that the machines aren’t more energy efficient (the web brochure doesn’t seem to distinguish between the vented and the condenser?). Any comments?
My wife would also like a machine which is not white – an integrated machine might be one solution to this, but they seem to be quite rare.
Thanks for any advice
November 12, 2009 at 12:28 am #303265kwatt
KeymasterRe: Choosing a new dryer
Hi Chris,
A few things…
Where did the figure of £60 come from and how was that figure arrived at?
There’s a lot of disinformation out there concerning energy labels. 😉
The best advice on energy use possible we give in the brochure, don’t use a dryer to dry clothes if you can possibly avoid it.
Vented -v- condensor is an old debate and, regardless of which you use they are not exactly eco-friendly. There are however pros and cons and, IMO, vented is the way to go.
To get a A rating on a dryer there’s two possible ways…
1. Take hours upon hours to dry, you may as well hang them on a clothes rack or whatever.
2. You use a heat pump type affair, effectively a refrigerant system in reverse. This involves substantial extra cost, complication in execution, weight and cost in production which will, in all likelihood never be paid back in use unless there is substantial use of the dryer and this is unlikely in a domestic situation. Fine in a commercial laundrette or whatever situation but, for domestic use given the current technologies, not a preferred route.
HTH
November 12, 2009 at 8:28 pm #303266helo_75
Participantok, so look at the bigger picture
buy an ise.. trouble free drying for ten years
or
buy one of that merloni tosh.. ie hotpoint/indesit
buy another hext year
and one the year after
and the year after18 months at best for next one… not to mention all the phone calls, petrol and waiting in and days off
this WILL go on every 12-18 months, believe me
not exactly saving you money is it
people need to stop reading the corporate bull and accept the facts…
just look round the site as to how many dont heat/snap belts/drim shafts snapping/ scrape/ blow up/ dont dry .. that is if you can get in the dam thing cos the handle just broke off!
its obvious what im getting at, really
November 12, 2009 at 9:43 pm #303267Chris_B
ParticipantRe: Choosing a new dryer
Thanks, kwatt.
The cost of electricity was worked out from the energy to dry a load, times 365 days in the year (used once a day on average), times cost of electricity, then subtract the figure for the Siemens from that for the ISE. The Siemens is quoted as 0.27kWh/kg, but I had to guess the energy use for the ISE from its C rating as I couldn’t find a figure – I took the middle of the band as 0.63 kWh/kg.Problem is the Siemens figure is very low, as good as the Miele Heat Pump, so I’m not sure I trust that info, and the ISE is higher than I expected for the ethos of the company – hence asking for advice.
Thanks for your other points – I have put in an old fashioned ceiling rack on pulleys – but we do a lot of cycling, canoeing etc so have lots of wet kit.
helo-75 – thanks, but I think you’ve picked me up wrong. I’m not thinking of buying a Hotpoint – I’m about to bin one and don’t fancy another, for all the reasons you say. I’m asking about Siemens v ISE, or in general, quality machines and how much can I trust the energy ratings?
Given that a dryer will use from one to several times its purchase cost in electricity, the amount it uses is quite important. Is there an independent source of energy data?
Chris
January 17, 2010 at 11:16 pm #303268jat63
I am also very interested in this. My current drier has just died and looks like I am about to purchase a new one.
Which? has the quote for the Siemens WT46W560GB:
“This means that a full 7kg load of cottons will only use 2 kWh of electricity and will cost about 25p.”
Now if it lasts 10 years and its used 300 times a year (about my usage) that comes to £750 at todays prices which are bound to go up. So – purchase cost of £800 inc 5 year warenty gives a price over 10 years of £1550 plus repairs in the second 5 years – anyone any idea what these might be likely to be?
I am very interested in what the comparable cost would be for the ISE drier. The purchase price is lets say £700 – so £100 difference. Looking at running costs the quoted cost is 0.73 kWh / kg or or cost or 63p per load. That seem to give a running cost of £1890 over the 10 years. So a total cost of £2590 over the 10 years.
At those prices I could purchase another new driver if the Siemens broke down after 5 years.
Do these figures look Ok or am I missing something?
January 17, 2010 at 11:38 pm #303269kwatt
jat63 wrote:Do these figures look Ok or am I missing something?
Yes.
The amount of electricity that you actually use will vary dependent on the load, the load size and the dampness and this is especially so with sensor dryers which, by their very nature, are designed to minimise the use of electricity.
You can’t calculate that as it will vary from load to load.
Therefore, a direct comparison isn’t really possible other than a theoretical one based on the doing the same load, with the same level of dampness, under the same conditions repeatedly and consistently. Obviously this is not possible in real world use.
The examples that any manufacturer will give you are just that, examples carried out, usually under optimum or typical conditions. It doesn’t mean that’s exactly what you’ll get every time.
I’m really surprised that Which? didn’t point that out as it’s so basic a premise to explain to people.
HTH
January 17, 2010 at 11:47 pm #303270aqualectric
The Siemens is £899 at John Lewis; £780 at Boots making it at best £100 + more expensive than the ISE condenser drier and £200 more than the vented version. The Siemens has a 2 years guarantee as standard and you have to apply for the extension to 5 years (some are charging £75 extra). ISE driers have a full 10 years parts and labour warranty and when the warranty is up, the spares are supplied to you with no mark up. Local service is usually less than half the cost of manufacturer call out. If you have seen the prices of Siemens spares you will appreciate the difference. The heat pump is air – con in reverse and aircon is not cheap to fix. They run with little heat as the heat is gleaned from the drier’s surroundings.
The energy calculations in an ideal world are all well and good, but when the repairs come in (and all machines break) you will be able to buy a lot of electricity for the cost of the Siemens spares and labour charges. You’ll get free spares AND labour for 10 years with ISE. Also, it is important to remember that machines were built better 10 years ago. You can’t really compare a machine from 10 years ago with today’s offerings. Siemens appliances are good, but weigh up the differences in the long run.Hope that helps,
Steve.
January 18, 2010 at 12:11 am #303271kwatt
I didn’t realise that someone was comparing a heat pump dryer against the ISE dryers, that’s like, comparing apples and oranges really.
I think it’d probably be best to explain what heat pump dryers actually are and how they work and, if you Google “heat pump dryer” you can glean a load of info to back up what I’m about to say…
In a commercial, high volume situation they are very worthwhile as an investment, even if the maintenance costs are slightly higher but the savings are attractive enough to make it worth taking a punt on it commercially. In a domestic situation, the jury is out.
Domestic heat pump dryers have only been around for a few years and, as Steve has pointed out, they use what is effectively a basic air-conditioning type reverse heat pump type system. How well that works in the real world is up for debate, thus far I’ve not seen too much support or raving about how wonderful it is from the trade and the long term reliability is, as yet, a total unknown.
How well they work in adverse conditions, especially in terms of ambient temperatures, is unknown, to us at least.
The effect of shoehorning a refrigerant system into such a small space with loads of heat about is, unknown.
The costs to effect repairs or, even an average repair cost for this sort of system is, unknown.
With the unknowns, the chances of getting a long warranty (other than at great cost) is practically zero. In fact, if someone signed that off with an insurer they’d probably get fired for being stupid and, if not, they should be.
IIRC Andy Trigg reviewed the Electrolux version on Washerhelp and he (or his better half) wasn’t very impressed with it.
If you buy one however you do get a warm, fuzzy feeling that you’re doing something right for the environment and saving electricity.
Trouble is, they have a lot more bits in them and take a lot more to actually manufacture in the first place.
You never get a free lunch in energy terms I’m afraid.
As you may have sussed, I’m deeply unconvinced by heat pump based dryer technology as yet although I applaud the effort and wish it were a “magic bullet” cure for the problem of drying, I don’t really think it’s the answer. 😉
January 18, 2010 at 12:33 am #303272Penguin45
The Bosch…
Compressor – £178
Drive motor – £100
Computer board – £235.34Ouch.
January 18, 2010 at 8:00 am #303273jat63
Thanks for all teh advice. So it basically comes down to this:
I may save up to £100 per year in electricity with the Siemens based on my loads.
Over the first 5 years both machines are covered by free parts and labour.
Over the next 5 years ISE will continue to cost zero and Siemens will start to cost – and that cost could be quite a lot.
After 10 years ISE will also cost but at a greatly reduced rate.So basically if repair costs average less than £100 per year I am better off with Siemens and if more with ISE (I will have a repair fund of about £400 to start with after the first 5 years). At the moment the potential costs for this new type of machine are unknown and some parts could easily on their own use up 2-3 years of this saving potential.
Does this look closer?
January 18, 2010 at 8:46 am #303274kwatt
I really don’t know jat.
Heat pump dryers are rare at the moment and just what the actual savings are in a domestic setting with small loads are unclear when they are in actual use by real people.
It makes sense in the commercial world where you’re doing 15kg+ loads but it hasn’t even been that widely adopted there either, why I don’t know as, again, there doesn’t seem to be too many around. I suspect that it is liable to be performance issues that are holding it back, time taken to dry a typical load would be the first question I’d be asking as if it takes a lot longer the commercial world will shun it in large part.
But just how much electricity you will actually save you won’t know until you use it.
HTH
