Choosing new hob and oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Choosing new hob and oven
  • #78746
    Kommunist
    My mrs have decided that she needs a new hob and oven.
    At present we have a bog standard AEG hob which recently developed a fault: the ignition doesn’t work on two burners.
    The oven is el cheapo Candy which is sort of working but it takes a looooong time before it is heating up and grill have stopped working the other day.
    One constraint – the appliances have to be either white or cream to match the kitchen.
    So I selected the following for her:
    Hob: Bosch PCP612B90E (gas)
    Oven: Bosch HBA13B120B (single, electric)
    Do you think this is a good choice?
    I can probably stretch my budget by going to the following:
    Hob: Bosch PPP612M91E
    Oven: Bosch HBG53R520B
    However, is there any compelling reason for doing this (aestetics aside)?
    Thank you!
    #406748
    don
    Re: Choosing new hob and oven
    Bosch is always a good choice 😉 whether you need to go all the way with the upper models only you can decide if you want / need the extra functionality.
    Bosch site here allows you to compare a few models at a time, you can also do the same with the hobs a swell.
    HTH 🙂
    Don
    #406749
    Kommunist
    Thank you!
    I was wondering if these models are “real” Bosch or a rebranded Balay. I guess the only way to find this out is to look at the “made in …” label, right?
    #406750
    don
    Balay was dropped from the UK core range some years ago 😉
    Bosch produce products all over Europe in their own factories. The Loggixx range tends to be made in Germany the rest around the EU.
    Don
    #406751
    Kommunist
    Didn’t know that 🙂
    The Logixx is too expensive and got lots of features my Mrs won’t be using, so I am more inclined towards Exxcel or even Classixx (why they so obsessed with double-x these days? :))
