CI555 – Noisey motor
  • #55918
    Goatboy
    Anyone else had this one?
    CI555 – 5×5
    Custumer complaint – Noisey on spin.
    When I has a look at it, there’s a horrible fast rachet noise, like an armature segment raised or a brush on upside-down.
    On closer inspection, the armature has undressed itself…
    Is this going to need a new motor? Did it Friday, and I aint heard back from the customer yet! Fingers crossed :innocent:
    #325577
    Re: CI555 – Noisey motor
    Had several like that, always needs a new motor, the armature has cooked.
    Even had one on a three month old machine once.
    Goatboy
    Just phoned the customer, and the boss wasn’t there, but the daughter says it’s been working fine all weekend 😕
    We’ll see!
    #325579
    megawatt
    Had a few like that. Mine had not cooked but the protective clear plastic film had come off the armature. I cannot see why it is needed so I pull all the plastic out, test the machine and hand it back. No call backs as yet.
    Mike.
    #325580
    aqualectric
    Zanussi FJ series with the Sole motors from the mid – nineties did this regularly. It didn’t have any affect on the working or reliability of the motor. We used to megger them to be sure they were safe; I don’t recall one that failed sooner due to the plastic being removed.
    Steve.
    #325581
    cornwell40
    Had the same a couple of years ago on same machine. Machine still running no problems…..on motor since 😉 .
    TC
    #325582
    Must admit I’ve not had one for a good while now, most of the early ones were at the time we had the dodgy brushes supplied.
    However as I mentioned, one machine was only a few months old, lightly used and brushes although like a piece of coke on the ends were hardly worn at all.
    I wasn’t going to risk sticking new brushes in that one. 😉
    #325583
    Goatboy
    Tis one I fit Hoover brushes on (about a year ago) because I didn’t have any ISE ones.
    Genuine Hoover though. Never had a problem with the genuine ones. 8)
