CI555WH pressure switch
  • #81106
    Does anyone know the correct part number for the pressure switch, listed as E006 in my old documents?
    Re: CI555WH pressure switch
    A very rarely used part Jim…. in fact we have zero use showing.
    Part number is: 2819710200 or 2805890200
    Changes on the tank so David would need the serial number to determine which but more likely the second one.
    kwatt wrote:A very rarely used part Jim…. in fact we have zero use showing.
    I have only used one in the 8 years they have been in the field and didn’t bother re ordering for that reason.
    Pressure switch
    Not certain that I need one for my current ‘weird fault’ yet, different symptoms and last error of 101 and a pump change has not resolved the intermittent problem.
    Will check on serial number in my records if I need to try a pressure switch. 😀
