this is a machine i aquired the drum totaly gone usual problem , i have some spare s/h drums so i fitted one and generally refurbished the beast , however whatever program i select it just keeps going even with no load in , i tried a s/h c/panel but to no avail any help gratefully recieved
will check that deltra thanks , apparantly a local engineer knows someone whe works in technical dept, at crosslee so i will probably get help there if necessary
The stainless band around the drum is mounted on a plastic strip to insulate it from the earth. The metal bars on the paddles are connnected to the band by springs to complete the resistivity circuit. If the brush is running against a plain metal drum, you have a circuit to earth and the sensor circuit will not function.
