Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › clarify wd12 indesit w dryer
- This topic has 18 replies, 7 voices, and was last updated 16 years ago by
adv.
March 15, 2010 at 5:09 pm #53247
adv
Participanthi guys got this machine, flashing 13 times. picked up fault code sheet from supplier.sayin f13 is a water supply fault, on none lcd machines an f13 on lcd machines this code means dryer heater senser. is this correct? 😆 ?
March 15, 2010 at 5:15 pm #315035A1engineer
ParticipantRe: clarify wd12 indesit w dryer
f13 on these is a dryer fault, check ntc, heater or blcoked condenser.
March 15, 2010 at 5:25 pm #315036adv
not on this hotpoint fault code sheet it aint that only applys to the lcd ev01 evo2 machines 😆 ?
March 15, 2010 at 7:14 pm #315037iadom
ModeratorRe: clarify wd12 indesit w dryer
F13 is F13 across the range…wether or not it is a digital display or flashing lights.
Dryer NTC related fault.
March 17, 2010 at 12:30 am #315038Penguin45
Right, I’ve explained it in the other thread, so let’s start again.
A thermistor, or NTC sensor is used to signal the pcb to regulate the temperature. This is not a bi-metallic thermostat. It does not get hot and go click. Remove the device which looks like a thermostat and connect your test meter across the terminals whilst set to the kOhm range. When you warm it up, the resistance through it will fall slowly. If there is no circuit at all, it’s goosed. If the resistance doesn’t change, it’s goosed. If you don’t get similar readings from the connector at the pcb, there is a wiring issue, or the NTC is goosed. If it all checks out, the pcb (being Indesit) is goosed.
F13 is a specific fault, relating to the temperature control circuit. A blown element, a failed safety cut-out or microtemp will not generate a code, you simply won’t get any heat on dry.
I don’t think I can make it any simpler than that.
March 17, 2010 at 8:47 am #315039adv
cheers
March 17, 2010 at 1:14 pm #315040eastlmark
adv wrote:hi guys got this machine, flashing 13 times. picked up fault code sheet from supplier.sayin f13 is a water supply fault, on none lcd machines an f13 on lcd machines this code means dryer heater senser. is this correct? 😆 ?
why do you need “to pick up a fault code sheet” from a supplier when you have them here?
March 17, 2010 at 2:28 pm #315041Martin
eastlmark wrote:why do you need “to pick up a fault code sheet” from a supplier when you have them here?
But how handy is that that suppliers are giving out fault code sheets? I wonder who the supplier is? Wouldn’t be eSpares by any chance would it adv? I wonder if you can scan it and send me a copy anyway, my email address is below, just click on it ….tnks! 😀
March 17, 2010 at 2:43 pm #315042adv
its same one thats listed in the known fault codes mate 😆
March 17, 2010 at 3:00 pm #315043iadom
Where does it say that in the Known Error codes thread though. 😕
March 17, 2010 at 3:12 pm #315044adv
page 5 hotpoint error codes f13 water supply ist paragraph if am mistaken lol 😆
March 17, 2010 at 3:19 pm #315045iadom
If you mean THIS post from Gegsy the first list of machine fault codes in that post is for old, pre Indesit corrupted Hotpoint machines going back twenty years or more in some cases. 😉
Both of the two lists below that for EVO 1 & EVO 2 give F13 as NTC related fault.
March 17, 2010 at 3:29 pm #315046adv
yeh thats the one they gave me the sheet with codes mmm
March 17, 2010 at 3:32 pm #315047iadom
adv wrote:yeh thats the one they gave me the sheet with codes mmm
So are you going to tell us who ‘they’ are then. 😀
March 17, 2010 at 3:36 pm #315048adv
edinburgh components there the main supplier of parts in edinburgh for the last 30 years 😆
