CLASSEQ Model D500 glass washer leaking
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries CLASSEQ Model D500 glass washer leaking
  • #99042
    mike100
    As soon as starts to circulate it leaks from either side of the door. Heats ok .
    Not used to commercial appliances so any help appreciated.
    Thanks, Mike
    #474817
    Hollytree_Technical
    You will need to clean the top inside edge of the lower front panel in the vicinity of the door hinges, also check if the drainage channel in the corners below the hinge are blocked, these are the usual culprit on most commercial dishwashers/glasswashers.
    Jem
    #474818
    agree with Jem
    there are channels inside to catch the water coming down from the door. They get blocked with all sorts of goo and rubbish
    put your head inside with a torch and look under the door in the corners
