Classi XX Bosch dish water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Classi XX Bosch dish water
  • #76542
    Eughurley
    W have one of these and it is not emptying out, leaving an amount of dirty water in the inside. Tried looking at various parts, but cannot detect why this is happening….any ideas welcome and thanks in advance.
    #398729
    Andy jones
    Re: Classi XX Bosch dish water
    If you manually drain water out. Take out filter you should see a cover that conceals the pump impeller. Take this cover off (torx screw). You will probably find something jamming the impeller. Glass is quite common
    #398730
    ther are 2 main reasons
    1 The pump is jammed bits of glass etc ( as in post above )
    2 Your drain hose is blocked. Get it a lot when people put fat down the drain
