Classic Eco 2 Glasswasher. Mod EC02/MK2/DF
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Classic Eco 2 Glasswasher. Mod EC02/MK2/DF
  • #18468
    Ashby
    Hi, Local pub have asked if i’d have a look at their glasswasher. not taking in detergent or rinse aid. which are both syphoned in from containers either side of the machine. I’ve never looked at one before. if anyone knows something about this i’d appreciate your help. Many thanks.
    Ashby.
    #179140
    welsh__boy
    Re: Classic Eco 2 Glasswasher. Mod EC02/MK2/DF
    Seeing as they’re both not going in, I’d check to see if the machine isn’t sitting on the tubing, could be as simple as that. The detergent is pumped in using a peristaltic pump, any old oem type will do, the rinsaid is pumped in using a diaphragm pump which is either activated using the water pressure from the main wash motor or the mains water pressure from the rinse tank via some hose. Simple way to test the detergent pump is to check 240v. If the machine came with a factory fitted detergent pump and there isn’t 240v, one of the relays up top is probably faulty. Easy way to bypass that is to run the pump straight off the solenoid. If the pump was retro fitted it should already be off the solenoid, therefor pump is knackered. As for the rinse pump, could be a split or torn diaphram, the one way vavles in the pump itself may have stuck, the mains water pressure (if from the rinse tank) may be too low to push the diaphram. The pump itslef may have clogged up with debris, could be a number of things. If you need part numbers etc, let me know.
