I would like to remove the two sheets of glass from the oven door so I can clean them. I’ve been able to remove the door by following the instructions in the manual but I can not see how to disassemble the door. Any tips?
Usually there will be a few screws to undo, primarily the door handle that will allow it to start to come apart, so long as it isn’t one of the silly bonded ones. After that it should be fairly obvious.
