‘Clean Pump’ Light Whirlpool AWO/D 4505
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ‘Clean Pump’ Light Whirlpool AWO/D 4505
  • #76181
    jacktrigg
    Hi – Apologies that my first post is one begging for help – it’s quite selfish of me, I’m aware!
    I’m getting pretty desperate now though – my washing machine is acting extremely strange.
    At the end of a wash cycle the water drains from the drum in 2 stages (this is when testing on quick wash mode):
    Stage 1 – The bulk of the water is quickly drained out of the tub without any issue.
    Stage 2 – a pulsating noise from the pump. it sounds like it’s turning on and off once a second. Maybe very slightly quicker than that.
    After doing stage 2 for about 2 minutes – the clean pump light comes on.
    This is odd to me as there is nothing obstructing the pump. I have remove the filter and all is clear. I have had the drain pipe off of the pump and completely cleared this of gunk and debris and I have remove the pipe from the tub to the pump to ensure that was free flowing too.
    I am all out of ideas and it is destroying my soul – could anyone point me in the right direction? What should I check next? Does the drain pipe have to be set at any specific angle to avoid air locks?
    Thanks!
    #397489
    Re: ‘Clean Pump’ Light Whirlpool AWO/D 4505
    Sounds as if the washing machine is not detecting that it is empty.
    Usually a blockage but could be something to do with the pressure switch or sensor possibly.
    I’m not familiar with the model so that’s as much as I can offer you.
