Called out for no dryer heat and and found the stat needed resetting. I went to remove the duct for a clean but found it to be moulded into the tub which makes checking for a blockage impossible. I cleaned it blind as best I could using a flexable rod and a rag, but I was unsure as to how successful or unsuccessful I was, the next few dryer cycles will tell. Has anyone had more experience on these ducts and found a better method of cleaning?
Mike.
