I am enquiring with regard to Siemens oven, HB75LB550B pyroclean oven.
There are streaks of dirt on the inside of the triple glazed door where liquid (condensation from moisture during cooking?) has run down the inside of the glass. It is on the inside of the outer glass and the inner glass but also on the middle glass. Is it possible for a competent DIY’er to remove the glass in order to give them a proper clean?
There is also a residue of little black specs on the inside of the door after a pyroclean cycle which don’t wipe off, is there a way of removing these?
Many thanks
