Clear error e21
  • #93833
    CARLJONESDAR
    Can someone help? The job is a bosch WAK28261gb/11 error E21. Replaced worn brushes and tested motor (ok). Cant get error code to clear, starting with knob at 12 o’clock I’ve turnet knob to 6 o’clock, pressed rpm button then turned knob to 7 o’clock, held for 5 seconds and released, turn knob back to 12 o’clock but its not cleared. Is there a different reset for this model? Thanks for any help.
    #455658
    Re: Clear error e21
    ……or try unplugging the motor then carry out the usual 6 o’clock reset procedure. Plug the motor back in and repeat that procedure…..fingers crossed 😉
    #455659
    Re: Clear error e21
    also from my experience you have to do the reset procedure in a methodical way
    turn to 6 (wait 2 secs)
    press and hold spin button (wait 2 secs)
    turn knob to 7 (wait 2 secs)
    now release spin speed button
    at this point the start button might well start flashing which means success. turn machine off and on again and see if it works
    have had other dealers say it can take several attempts to reset and I myself have had it take 2 or 3
    CARLJONESDAR
    Re: Clear error e21
    Sorted now thanks, it was different, from 12 o’clock press and hold start button and turn left one click, release start button and turn off. Thats it.
    #455661
    Re: Clear error e21
    yes there are a few different resets and no way of knowing which one does what
    it quite a relief when it resets and you know the machine is going to work
