Clicking Noise
  • #36294
    edkell
    Two problems that are probably related to each other. When I switch on the ice maker on our Side by Side Whirlpool S25B RSS31 a clicking noise can be heard. It appears to be coming from the back. Once I switch it off the noise use to stop, but now we hear it intermittently. The strange thing though, if I open the fridge or freezer door the clicking stops.
    The same noise can be heard once I use the water dispenser. It’s as if there is not enough pressure.
    Any help would be appreciated.
    Ed
    #250374
    Re: Clicking Noise
    Very common problem..The main PCB,You may need to change both the front and rear board,please supply the model and full serial and service number.
    Bryan
    #250375
    edkell
    Re: Clicking Noise
    Sorry for the delay, I thought I would get an email alert when someone posted a reply:
    The info I could gleam from the fridge is as follows:
    Model: S25B RSS31 A/G
    Service: 8586 166 15012
    There is also a number to the far right, but I can’t read the title: 11 0350 005487
    I hope this helps, thanks for the assistance.
    Should I be overly concerned about the noise? Is it likely to catch fire, or stop working?
    Ed
