Clothes look worn after washing
Home Forums Public Support Forums General Enquiries And Questions Clothes look worn after washing
  • #95675
    beneinhants
    I have a Bosch washing machine, I set teh temperature at 30 and teh RPM at 800, and my clothes comes out looking worn.
    I use liquid detergent and a Calgon Tab.
    Clothes look terrible.
    #461026
    Depends on the soiling on the clothes but tbh I will only use a good quality powder and would never wash anything at 30C unless it was more or less clean and just wanted a freshen up. I use green box Ariel for whites etc and purple box powder for coloureds. Minimum temp of 40C for colours and 50 to 60C for whites.
    #461027
    steveDAS
    why are you using Calgon Tab all the time are you in a very hard water area,
    #461028
    Owens87
    Hey. Try changing the detergent and rinse aid, this is probably the reason. I came across a similar and after replacing the detergent everything is fine.
    #461029
    Are you staying in a hard water area?
    #461030
    Abderian
    Change the detergent this can be the reason why clothes are being worn.
    #461031
    elyssarob65
    change your detergent, maybe the problem is in it.
