Coca cola fridge thermostat
  • #12195
    Simon46
    The local butty man has a tall coca cola fridge in his caravan for the cans of coke which i suspect the thermostat has gone on. The setup is evaporator in between the cabinet rear and rear panel with a circulation fan mounted at top with defrost tube at base of fridge. What would be the correct stat for this? Capillary tube is on evaporator. Would a K59 with long capillary work?
    Free breakfasts hopefully looming 😆
    Regards
    Simon
    #148316
    tonyclifton
    Blocked
    Re: Coca cola fridge thermostat
    hi simon46,
    cant rememeber which one but try abbeychart ltd or peachman one should be able to sort u out
    regards tony
    #148317
    hi tony
    it will need a fridge air thermostat,i think i have one ifyou need it
    bryan
    #148318
    Simon46
    Thanks Tony
    Unfortunately it was the compressor.
    Will have to pay for Bacon and Egg now. 🙁
    S.
    #148319
    pup
    hi
    try ranco vb7 bottle cooler stat
    #148320
    Simon46
    Bryan out of interest for next time how much are the fridge air thermostats?
    S.
    #148321
    pup
    hi
    what are air stats ?
    #148322
    hi simon / pup
    pup.. an air stat is a thermostat that registers the temprature of the air rather than the evaperator temprature.
    simon.. i’ll have a look and let you know as i only use them on american appliances now.
    bryan
