Code required for Whirlpool ADP 2756 WHM dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Code required for Whirlpool ADP 2756 WHM dishwasher
  • #6188
    sbryden
    I have a Whirlpool ADP 2756 WHM dishwasher, about 3 years old. It recently started aborting the cycle just at the point where the water was being let in. I thought I had traced the problem to a bad connection to a sensor which sits just around the mains water inlet point. I cleaned the connector to this sensor twice, each time giving me a few weeks more service, and I eventually soldered the connections, but it is still failing.
    The model is french, but with appropriate translations the error code is:
    Start light flashes 7 times between pauses
    Drying and End LEDs flash (last two of four LEDs on the top row)
    Can anybody please translate this code to give me a clue as to what’s going wrong?
    Also does anyone know if service manuals are available for this model?
    Simon.
    #116113
    DentedPorsche
    Re: Code required for Whirlpool ADP 2756 WHM dishwasher
    Hiya,
    F7. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked
    Hope this helps.
    DP
    #116114
    sbryden
    Thanks for that – at least I was on the right track. I’ll take a closer look – maybe it’s something as simple as a clogged inlet. Could I be so lucky??
