coding module on Bosch sgi45e15gb/31 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries coding module on Bosch sgi45e15gb/31 dishwasher
  • #80128
    bmrenr
    Hi this is my first time coding a Bosch module I got a page with instructions but they are a bit vague does anyone have better instructions the part no for module is bsh644395. Any help greatly appreciated.
    Tom
    #411759
    Re: coding module on Bosch sgi45e15gb/31 dishwasher
    I don’t have a copy but do send me a photocopy by email and I can help you there.
    #411760
    bmrenr
    Hi Martin will do but could u pm me your email adress as I dont see any option to attach a photo when I click on your email icon to send you an email.
    Tom
    #411761
    Just email me without in order we make contact first.
    #411762
    bmrenr
    Mail sent
    #411763
    bmrenr wrote:Mail sent
    OK got the configuration instructions from you now, thanks! 😀
    All you need to establish is what programme options (icon symbols) your model has in relation to the specific rotary switch positions. Then, from the config chart find the respective code ( i.e C1 – C6). Then follow the instructions as to how to check what the the default code is and alter it if necessary.
    I hope that helps you?
    #411764
    bmrenr
    Cheers Martin I’m stuck at which code to select the intensive wash on this m/c is at pos 8, 9 is Eco, 1 is quick, 2 is rinse, and 3 is reset. and also s2 is 1/2 load.there is only two options with 1/2 load c3 and c4 but they both have auto at pos 8. Have you come across this before?
    Tom.
    #411765
    I haven’t come across that before. I would set it on C3 if I were you as that seems the closest. What is the default setting anyway?
    #411766
    bmrenr
    Will try that Martin c6 thanks for your help
    Tom
